SatDreamGR on Edison OS MIO 4K | SatelliteGuys.US
JFOK
1,115
858
Cape Cod - MA.
Brian,
I went to the SatDreamGR forum and saw 9 zip files for the Edision OS MIO 4K.
Do I download all 9 zip files for installation ?
Also... can I make a back up of the OpenATV image using a usb thumbdrive ?
Thanks,
John
Reactions: Titanium
Brian,
Thanks,
John
John, looks like we can download EITHER of these two on the bottom. Later date then the rest, and I assume only difference is one allows "Multiboot" capability, which could come in handy later. I use 7-zip to decompress, it's better than Winzip, and it's free:
Satdreamgr-6-osmio4k-20190121-multiboot.zip
OR:
Satdreamgr-6-osmio4k-20190121.zip
P.s. Well, from looking around, I take it the "gr" is short for Greece? LOL
P.P.S. 1 backup is not enough. Personally, I wouldn't feel safe without a minimum of 4 backups, on different drives, and NOT all placed in the same location.
Reactions: JFOK and Titanium
Brian,
Thanks,
John
Yes, you may use use a USB thumbdrive to make a back-up.
Only download one zip file, the latest image. Today, that would be the zip file dated 20190121 (not the multiboot).
1. Unzip the folder osmio4k onto an empty FAT32 formatted USB thumb drive.
2. Open the folder and change the filename on one file from "noforce" to "force".
3. Remove the power cord from the OS mio 4K.
4. Insert the USB thumb drive into the OS mio 4K.
5. Attach the power cord and the SatDreamGR image will be automatically installed as the main operating system (position 1 in multiboot).
6. When the OS mio 4K reboots, immediately unplug the USB from the STB. (Please note that if this thumbdrive is plugged into the STB with the osmio4k folder containing the file name "force", the image will automatically be installed when the STB is powered on!).
7. The OS mio 4K is now operating with SatDreamGR image. You may now configure the settings and scan. :)
I have a few suggestions on adding and deleting a few plugins, so give me a call if you wish.
edit: Changed USB format to FAT32
My Edision Mio was also brought "special delivery" (REALLY!) by my mail lady this morning, way before our normal delivery. We are in the middle of another ice/rain/sleet storm, and she made the decision to run out early and only deliver priority mail packages! It's smaller than I was expecting from the photos, LOL.
It's warming up right now, but the wife and I both are going though the Flu (me almost to the end, she's in the middle of it) and she's off shift for today and tomorrow. So, earliest I'm likely to be able to hook this up for complete setup is Saturday.
I also saw the post from Brian about making sure you have HDMI cables capable of 2.0 18Gbps, and I have some of those on order. For now I'll use my newer high-speed ones and hope for the best, none are more than 6ft anyway. I don't have a 4k tv set as of yet anyway, and HDMI CEC is turned off (I hate it! Never works right)
Reactions: Titanium and JFOK
Using Amazon branded HDMI cables with mine and so far no issues :)
Mike ,
Glad it arrived despite the ice storm. I haven't started with mine yet.
Hope you and the wife are feeling better soon. I had my flu "experience"2 weeks ago.
John
1. Unzip the folder osmio4k onto an empty FAT formatted USB thumb drive.
Brian,
Thanks for the instructions....they're very specific.:)
I'll be using them hopefully within the next few days.
I will call you as you suggested re: plugins.
John
<snip>
Really? FAT format only, not FAT32 or even NTFS?
P.S. Flu sucks! IF you get the shot but still get the flu, they'll tell you: "Must have been a strain not covered in this years shot!". IF you don't get the flu, they'll tell you: "Good! Then the shot must have kept you from getting this years strain!". LOL, you can't win...
John's post was broken off and moved over to the Linux/Enigma2 subforum per my request to the moderators. Meet you there to continue the conversation...
edit: Oh, I guess it is still here... LOL
Sorry, FAT 32 format is fine (but remember the limitations of 32GB). For compatibility between different images (because E2 is based on Linux) I would be hesitant to use NTFS for update/upgrade. With that said, Ext3/4 should be fine. I would tend to favor the most compatible type to minimize risk of corruption. Maybe that is just me...
I was starting to wonder if I couldn't see anything in that forum, because there's NO posts in it as of yet, at least I can't see any.
Anyway, no problem with just FAT, I really posted that to short-circuit anybody else wondering why something else wouldn't work. Thumb drives are likely to be formatted as nearly anything anymore.
Hi All,
Been "foolin around" with my new Edision OS MIO 4K for the past few hours and all I can say is WOW.
The set up was easy and even though I'm going to change from the factory installed Open ATV image, I thought I'd get familiar with the box first.
It actually shows that its a more sensitive receiver as I can receive more channels with it even though my dish is less than parabolic. Its kinda given my old dish a new lease on life...for a while at least.
Highly recommend this receiver from what I've seen so far.
John
Hi All,
John
Which image are you doing this on, as I've been working on mine on SatdreamGR for nearly 6 hours, and I don't find it easy at all so far just blindly blundering through the menus...
I think I'm going to flash back to the image it came with, maybe that'll go better for me.
For now, I hooked my MicroHD back up. I'm just going to watch some tv and get rid of my headache, lol.
Reactions: JFOK
Mike,
I'm using the factory installed OpenATV 6.2.
Brian suggested i change to the SatDreamGR image, which i will do later this evening.
Sorry youre having issues. I will share what I find with the new image.
John
Reactions: primestar31
Hi All,
Well I tried to change the image from OpenATV 6.2 following Brian's detailed instructions to a tee.
After plugging in the usb drive with the SatDreamGR files, I plugged in the receiver to power and it boots to 100.
Then it shows "booting" for about 20 seconds, then what appears to be "lang" and there it hangs up with no further action.
There is nothing on my TV screen and the receiver's remote is unresponsive, just flashing a green light when I try to power off.
I tried this 3 times with the same result.
Any suggestions ??
John
Hi All,
Any suggestions ??
John
It sounds to me like the new image on your thumbdrive is corrupted, what program did you unpack it with? I used 7Zip. I would try this if it isn't too late (using Windows?):
1: DELETE the satdreamgr file on your pc you unzipped previously.
2: Unzip a new copy
3: Put your thumbdrive into your pc, and re-initialize it and format it as Fat32
4: COPY the extracted folder (the whole folder!) called " osmio4k " to the root of your thumbdrive
5: Double-click that " osmio4k " folder on the thumbdrive to go into it. CHANGE the name of the " noforce " file to " force ".
6: put it into the USB1 on the back middle of the receiver
7: Plug the receiver in, and hopefully it'll flash this time. Watch carefully. AFTER it finishes and reboots, but BEFORE it comes up to the menu, pull the thumbdrive OUT.
By the way, El Bandido at legitfta helped me fix the stuck system file I had, and I'm a lot further on than I was before. Still a steep learning curve, but I'm closer than I was. I'm off to bed now, it's after 11pm
Reactions: JFOK
How do I manually add a new satellite?
OS Mio scanning for Wi-Fi networks
Who Read This Thread (Total Members: 6)
