Remote Code for Manual DNS | SatelliteGuys.US
IP Address Configuration is set to Automatic by default. By default, Automatic IP address assignment is used. In this case, the receiver's IP address is obtained by way of a DHCP server.
There is a hidden menu that allows manual configuration.
Go to the Advanced tab under Internet settings. Press Recall, Recall, and Play.
Although I used fixed addresses in my router for my two Hopper3 receivers and my Joey3, I let the Hopper3 auto configure the internet settings.
Thank you Mr Weber. I forgot to say to go to the Advanced Tab in Internet Settings
I use the router's DHCP Reservations feature to hold a steady IP address. Very simple to use.
DHCP Reservations are useful to ensure that your network device always gets the same IP address BUT they may not help if your device has a poorly implemented DHCP client. The DHCP client does not know about the reservation so should attempt to renew the reservation when the life of the reservation gets to 50% and will repeat a renewal attempt at each 50% point until successful. Some implementations fail to follow the rules and will fail to recognize a valid response and then flood your network with bad DHCP requests or any number of other problems. Other DHCP clients have been known to not recognize some DHCP options causing the client to crash.
Sometimes the only fix is to assign static IP addresses at the device level, knowing how can sometimes be a godsend.
I wish I knew this stuff. I did a speed test the other day, my laptop and Hopper connected to the same Router via LAN. Laptop speed was 246 Mb/s. Hopper 3 was 108 Mb/s and Netflix on the Hopper was 7.58 Mb/s. Figure that one out
Reactions: charlesrshell
Looks like your ISP is throttling Netflix.
I don't believe that it is his ISP. It has been determined that the Netflix speed on the Hopper3 is less than the speed of the Hopper3. In my case my Hopper3 speeds are 100-117 Mbps while the Hopper3 Netflix speed maxes out at 15-19 Mbps. Netflix on my 4K Sony TV is 60-80 Mbps. Netflix on my 4K Roku is 17-20 Mbps. Netflix on my Amazon 4K Firestick has the highest speed at 114 Mbps. And yet I can watch Ultra 4K movies on all 4 devices with no apparent differences in video quality. Netflix speed on my Joey3 was 15.61 Mbps. Of course the picture is smaller on my bedroom Olivia TV.
Reactions: HipKat
Could this be a Dish imposed speed restriction so as not to use too much of the MoCA? MoCA 2.0's near gigabit-speed should provide more than enough bandwidth even with every possible activity of streams and multiple VOD Downloads and 4 HD PIP, etc. should still leave enough bandwidth on the MoCA, I would think, but maybe Dish being conservative for its own reasons we don't know about. and even if a joey client is connecte to the internet via Ethernet port, that not change Dish's H3 configuration regarding speed for Netflix. I'm just speculating, but I find it very strange that the speed would be so slow for Netflix on the hopper 3. Reason #139 to use our own connected devices to access streaming services:).
Reactions: HipKat
1) The Speed Test sites are not as accurate as one would hope.
-- Did you use the same Speed Test site for both the laptop and hopper tests?
-- NetFlix recommends Fast.com as it only tests download speed to see how well NetFlix should work.
2) Were the Hopper3 and Laptop connected to the same switch?
-- many switches in home routers are not GB capable, yes even some of the newer 802.11ac routers
3) Lots of people have reported the Hopper3 NetFlix speed reporting as very inaccurate.
Does the Hopper3 NetFlix client allow you to see your streaming rate?
The Netflix speed tests that we have reported are part of the Netflix app. You go to Netflix settings and scroll down to check your network. It will check the connection to Netflix server 1, Netflix server 2, and Netflix server 3. It then reports your connection speed. This works for the Netflix apps on both of my Sony TV's, my 4K Roku, and my Amazon 4K Firestick. The Netflix app on my Apple TV does not appear to have the diagnostics available.
For the Amazon 4K Firestick there is an app called Developer Tools Menu. This allows you to turn on System X-Ray and Advanced Options. When this is turned on it creates 2 overlays that stay on the screen regardless of what app is running.
The one overlay shows CPU usage of the 4 cores, memory usage, and network diagnostics.
The other overlay displays the audio and video codecs, input bitrate, frames dropped, resolution, and frame rate.
This is normally used by developers to test their apps on the Firestick.
I have found it useful when debugging Dish Anywhere on my sons's TV.
Another useful tool is YouTube's Stats for Nerds. It also creates an overlay with a lot of diagnostics.
Another useful app for the Amazon Firestick is Analiti (WiFi tester & analyzer). A detailed test gives a lot of information concerning your network.
Being a retired engineer in process control I like to compare using these tools
Reactions: HipKat
Here are screen shots showing System X-Ray with Dish Anywhere on my Amazon 4K Firestick.
Reactions: HipKat and TheKrell
Yep to number 3
Reactions: HipKat
Cost after the two year lock?
Least expensive way to get HD on tv2 without starting a new agreement?
