I'm trying to set up a fta system as cheap as I can. I have a viewsat vs2000 platinum receiver and a hughesnet dish. Can I get this setup to work?
Well your to far away to get a free Ku dishI'm trying to set up a fta system as cheap as I can. I have a viewsat vs2000 platinum receiver and a hughesnet dish. Can I get this setup to work?
At a minimum you would just need a LNBF like this: https://estsatellite.com/shop?olsPa...te-mk1-pll-ku-band-pll-lnbf-standard-10750-loWhat do I need for ku?
Yes, a receiver is likely the biggest expense followed by a larger dish if you decide to go further. Depends on your interests as to whether you will be entertained.Okay, so the lnbf is my starting point. Now, I see that most of the ones suggested are pretty much a fairly reasonable price. Am I right that my biggest expense will be the receiver? And with a new lnbf, will I get enough signals to keep me entertained?
Now you are!but none that I'm aware of in the USA
Limited time offer
