my Wally seems to be stuck on the testing installation mode. I have it connected to a dpp10006YB dish that might have the setup for the eastern arc. I'm so confused so any help would be appreciated.
Diplexers don't work well with Hopper 3 configurations. There probably is a hub in the mix though and that would cause issues.I bet there's a diplexor in the cabling. Make sure the cable runs directly from the LNBF, ports 1,2 or 3 and straight to the receiver
He's using the Wally to replace a Duo tuner, which is why I think the diplexor is still in thereDiplexers don't work well with Hopper 3 configurations. There probably is a hub in the mix though and that would cause issues.
The cable is run directly from the Wally to the dish. Could the problem be the Wally receiver? Should it work with this dish? Would I be better off just buying another dish?
Also, is the latest update for the Wally, U421?
Receivers are targeted to receive the update. You'll get it, be patient.Whenever I try and update to the newer version, it says it has the newest update., but the software is the u421.
Limited time offer
