Check to see what IP address your router has assigned to the Hopper and to your Fire Stick. You can usually find that info in the router setup, but if you can't, you can find them separately in the Fire Stick setup, and the Hopper setup menus.
At "Wireless/Access" part of the router webpage, I have one named Hopper3-br and two different things named amazon-3c00f6c04 and amazon-bd05f9991 under the 2.4GHZ tab.Check to see what IP address your router has assigned to the Hopper and to your Fire Stick. You can usually find that info in the router setup, but if you can't, you can find them separately in the Fire Stick setup, and the Hopper setup menus.
OK. The weird just got weirder. (not really....I think I noodled the answer after writing this. See below for my EUREKA moment)you can find them separately in the Fire Stick setup, and the Hopper setup menus.
Don't got one. I retired (as an independent Home Theater/Dish retailer) in 2010...just before smartphones became the thing. I finally had to get one because so many devices (Amazon Alexa, for one) REQUIRED one to complete a set-up. So I got the cheapest TracFone I could find (LG Style) and it doesn't have enough memory to DL Dish Anywhere.
The modem I have is branded "Motorola" but according to Xfinity is a Zoom Telephonics, Inc. Model MG7550 (router/modem purchased from Best Buy). I can get into the admin section, but it then looks Greek to me. Couldn't see any obvious problem that I could fix.
On edit: here is a description of my modem:
Motorola 16x4 Cable Modem & AC1900 Wi-Fi - Micro Center
You're a couple of posts behind. Keep reading, the answer becomes clear.He is using a unit that has the modem and router combined together in one unit. When he disconnects the cable not only does the modem stop but the router also stops.
Yes, recently this started happening to me too. Every day I have to log in to Dish Anywhere, even though I have "Remember Me" checked (using a PC).I'm constantly logged out everyday for some reason even though I've trained the browser to keep me logged in.
The "Remember Me" option does come in handy if you forget your password. Does it log you out after a certain amount of time within the same day? Does any message come up when it takes you to the login page?
Trying to use Dishanywhere on my fire stick and I need to log in again ugh.
However when I go to the activate page it comes up that that page can't be found? Any ideas? Also looked all over the site and nothing. View attachment 140230
Thanks. I did that but It still wouldn't work on my phone or my ipad but i got it to work with my desktop computer.
Limited time offer
