Another Boeing product malfunctioning?New info:
I doubt the age of the satellite had any factor in what happened.
- Boeing will update operating procedures to other spacecraft of the same model to prevent SW1's issue from occurring again
- AT&T will relocate one of its satellites to replace SW1 as backup
Boeing-built DirecTV satellite may explode in orbit after suffering unexpected malfunction
The large broadcast satellite is owned by AT&T's DirecTV, was built by Boeing and is operated by Intelsat.www.cnbc.com
It is not for backup internet in Alaska, not the primary mission.Probably not carrying insurance on a 15 year old satellite that is used for backup internet for Alaska though.
What are you saying is the mission then? It is (or was since it has probably started moving) directly over Alaska, and AT&T said they were retasking it to provide internet in Alaska. It is not providing any TV, and hasn't for several years.
It might be over the equator on a meridian that lines up with Alaska, but the satellite can't sit directly over Alaska.
The satellite is notably several years beyond its intended lifespan, as Boeing told CNBC the incident happened "beyond-contract-life operation."
The article said it was a backup TV satellite for Alaska.What are you saying is the mission then? It is (or was since it has probably started moving) directly over Alaska, and AT&T said they were retasking it to provide internet in Alaska. It is not providing any TV, and hasn't for several years.
Yes, in addition to the below...The article said it was a backup TV satellite for Alaska.
Plus, moving closer to Earth puts the satellite into Earth's shadow more often, increasing the likelihood the batteries drain and recharge, leading to the thermal runaway that causes an explosion.
I find it fascinating that you follow this.DIRECTV files request to move SW2 over to 138.9W to replace the disposed former SW1 ...
Should have been expected as the most logical move after SW1's recent mishap and demise I suppose ....
Sent from my LM-V405 using Tapatalk
Limited time offer
