Netflix cc problem | SatelliteGuys.US
Netflix cc problem
WildBill
180
40
Florida
Been having problems with cc (closed captioning) on Netflix the last few weeks. On several different series I'll find that cc works on some episodes but not others. For example, cc might work on episode 2 of Cheers, but not episode 3, and then it is back on episode 4. I've tried turning cc off and then back on (no luck) and starting the episode over (no luck either). Oddly, if I switch to Spanish cc it works, but still nothing when I go back to English. Is anyone else seeing this problem, and if so, do you have a fix?
Reactions: bspei
Hello, WildBill. We have been seeing reports made recently of other customers that are experiencing the same issue with the Closed Captioning through the Netflix app. At this time we do not have a fix or workaround. We do request that you reach out to our Chat Team here so we can submit a report to our Engineering Team with your information to add to the list of examples of this issue.
Hopper 3/Caller ID/DSL.
How to disable PrimeTime Anytime?
