N Nicperc New Member Original poster Sep 25, 2017 4 0 Kentucky Apr 7, 2020 #1 I have a swin 3D2Lnbro-02 LMB and I want to know if an HD 24 will work with it or do I have to go with an HD25. It has one LMB on the end, Thanks.
S slice1900 SatelliteGuys Pro Feb 14, 2015 1,748 798 IA Apr 7, 2020 #2 Nicperc said: I have a swin 3D2Lnbro-02 LMB and I want to know if an HD 24 will work with it or do I have to go with an HD25. It has one LMB on the end, Thanks. Click to expand... All HD receivers will work with that LNB.
Jimbo SatelliteGuys Master Lifetime Supporter Cutting Edge Jul 14, 2005 70,055 8,415 NW Ohio - Buckeye Country Apr 7, 2020 #3 slice1900 said: All HD receivers will work with that LNB. Click to expand... Is he talking about an HR recvr, or a H (which is High Def.)
S slice1900 SatelliteGuys Pro Feb 14, 2015 1,748 798 IA Apr 7, 2020 #4 Jimbo said: Is he talking about an HR recvr, or a H (which is High Def.) Click to expand... Doesn't matter, the same is true for all H2x/HR2x. Reactions: Jimbo
