Anyone using the Orthomode Feedhorn from TEK2000/Aliexpress ? | SatelliteGuys.US
pro96
You Member, Member ?
6,464
15
OC
Are they any good? Also aliexpress has them for about $49.00 (no lnbs)
Thanks guy for input. Those Chaparral orthos are just too hard to find nowadays.
I'll keep looking at craigslist and or ebay
i have a used chapperal with norstat 5150 needs a servo motor you can get get from hypermega sat ill be glad to send it to you free the servo motor broke off give it to someone who can use it mountain man of la
I been using aliexpress ortho with my 5150's.I purchased for $15 2yrs ago edit almost 3 now. it has been fine. I also have 2 chapparal 1329 and a couple bullseyes but have not had time to do any comparison yet. Used the chap scaler was on my dish. Was leary because price too good to be true but has absolutely worked fine, if I had any issue would have swapped it out long ago. Maybe build quality varies and i just got a good 1. It is not a 1329 clone does not have machined steps like 1329 has, it has tapered transition instead.
sent you a message
Thanks for the info on your testing.
Odom 10ft Mesh BUD Setup
Gale Winds - Sat ASC1 mover off by 16 ticks
