ports no signal | SatelliteGuys.US
ports no signal
stanleyman
2
florida
hi, newbie here, my dish hopper system check says ports 1,2, and 3 have no signal , everything else is good , I changed the hub with one from home depot, worked for a few days then out again, bought the right hybrid solo hub 203952 which did not cure the issue , any suggestions
thanks
:welcome to Satelliteguys stanleyman!
I'll move your post to the Dish forum for you.
thanks
Are you sure the Hub is connected properly?? ODU port to the cable from the Dish, Host port cable to the Hopper, Clients to any Joeys?
Perhaps it would help if these threads were merged, so that all of the advice could be given in the same thread.
Facebook chat with Erik Carlson
Google Assistant not working for voice on remote 54.0
