25 MS Latency is pretty nice, since Hughes/Viasat are about 650 MS+
They claim when fully rolled out, it'll be 1Gbs
Sounds like Hughes - which I install. Once you run out of your overpriced Data, it throttles down to 1-3 Mb/s, And I do mean overpriced. I think Hughes 50 GB/Mo is about $149.00Is this from Starlink's T&C or Hughes?
Are there data caps with Starlink?
No. HughesIs this from Starlink's T&C or Hughes?
Now I have to say that really sucks. I think everybody will want to plug in their own wireless router, so the "reasonable wifi range" is just (possibly) interfering with the customer's setup.The supplied router has 1 ethernet connection and has reasonable wifi range, but no device access for configuration.
I would imagine you can add a third-party router or Mesh system.Now I have to say that really sucks. I think everybody will want to plug in their own wireless router, so the "reasonable wifi range" is just (possibly) interfering with the customer's setup.I know you said you can only log in on their router and set a password... But can't you turn off their WiFi at all? Is their router/password a WiFi password? WPA? Do you still need to set this if you use the wired port?
You can use your own router, so put the Starlink router back in the box since I already have a LAN with a good gateway router, switches, etc.Now I have to say that really sucks. I think everybody will want to plug in their own wireless router, so the "reasonable wifi range" is just (possibly) interfering with the customer's setup.I know you said you can only log in on their router and set a password... But can't you turn off their WiFi at all? Is their router/password a WiFi password? WPA? Do you still need to set this if you use the wired port?
SL, DA? Not sure what that is, not a network engineer here, but maybe I can find an answer for you.Will they ship to an address where there is usually someone, rather than the service address? We aren't allowed to take deliveries at our RV, where we would want the service.
Also, I'd love to hear anyone's experience using SL and DA.
Any login mumbo jumbo if you bypass the Starlink router?You can use your own router, so put the Starlink router back in the box since I already have a LAN with a good gateway router, switches, etc.
The router is seperate from the modem (transciever, the dish-like antenna). There is also a POE power block that powers both modem and router through their network cables. This is what you plug into the wall to power both units, or the modem only if you use your own router.So Starlink provides a separate modem and a wireless router?
Wow. How are you supposed to tilt the antenna in the right direction without even a compass rose?The above is the complete instructions for the unit.
You don't. It does. And it even points north!Wow. How are you supposed to tilt the antenna in the right direction without even a compass rose?
Radio (packet radio?) internet will have to restructure their business model. Those services are usually a bit more than what starlink seems to be offering.A tech on our Tech Portal posted yesterday:
Starlink started sending out the Beta testing units about a month ago. You had to be chosen to be one of the beta test homes. Each customer is paying $500 for the kit and $100 month. I recently helped someone install his. Its very user friendly. There is a 100 ft permanently attached cable from the satellite that needs to get into the house. Even though the satellite adjusts itself, the volcano roof mount could be designed better. Overall, I think via sat and wild blue might go by the wayside with the speeds these dishes can give. I guess we'll see what the future brings.
If you search for an antenna teardown video you'll see it has 2 motor tilt array inside. And a slick phased array antenna. Pretty cool.You don't. It does. And it even points north!![]()
Limited time offer
