- Nov 29, 2003
- 17,132
- 22,355
120 degrees does not usually happen in December/January in the warmer/Hotter States, while 0 with that wind is a lot more likely in the Colder States.When it's 120 on the field with high humidity, or when it's 0 degrees with a stiff wind, not much you can do to prepare for either of those.
And while players can wear some layers under their uniforms (I read NFL players wear Nike Hyperwarm Flex, I assume College wears the same or similar), for certain players, some do not like wearing gloves ( they should), that cold can really mess up the hands.
