Whenever we DO go back, it'll be craziness!I hope so...but I'm not ready for those first calls that come in...
When Dish receivers lose their activation or were manually deactivated, they need yo be reactivated by the computerWon't the box at least start working overnight or in 2-3 days after it updates manually from the satellite? Or is that just directv?
I have done that... it will do the checking for signal thing, then eventually it just stops with that "this should take no more than 5 minutes". Screen....Unplug your Hopper for 30 seconds and let it reboot. See what you get.
Those pics were just now after unplugged for 2 mins and removed the RG-6 to the back, then I put that back on...I can change to any tuner or any satellite transponder and it shows zero signal and zero lock... it was fine Friday night at like 10pm CST, then Saturday morning like 8am nothing....
I sure hope they are not trying to extort Charlie, because he is pretty tight about controlling cost. He would never give in to their demands and they would pull the plug on the entire operation, just to spite them.Having been through this with my company in 2022 if this was a ransomware attack it is understandable why they are down so long. Typically the culprits are on your system observing and trying to get sensitive data for the blackmail phase of their actions for a long time before they expose themselves. They will then set off the encryption phase to lock your files. A good IT team will immediately disconnect the systems from the internet and start evaluating how widespread the issue is and if they have good backups start restoring the systems. The larger your system(s) the more monumental this task is. I believe this is why this has taken so long. They will keep the system disconnected from the internet until they have been able to restore and verify their backups. They also have to make sure the ransomware files have not infected their backups or it will just happen again. This will take time. You can also assume they are working with the FBI's cyber crime unit.
I hope for everyones sake you all are! My Dish Anywhere app had a update tonight so someone is working.I hope so...but I'm not ready for those first calls that come in...![]()
Switch Status is showing you the satellites it saw the last time it tested installation. Press TEST INSTALLATION. Most likely it will say "you have fewer satellites..." You can cancel or save at that point. The problem could be anywhere from the Dish to receiver.Just some rain but it was light... about 3 days prior it was fairly heavy, but not Friday. nothing major, fairly typical for Memphis, TN
Bite your tongue! Before there was Google Maps, GM (in the computer-sense) meant "Guru Meditation"…It was a wonderful thing at the time, ruined by their use of "Guru Meditations" instead of a more business like error message.
The first pic showing Tuner 1 transponder 0 is what we call the 0 of 0 Transponder glitch. Typically, when you see that Tuner shows 0, setting it to 1 and backing out to where it says Acquiring Signal, that status bar will start to turn green and restore your service. Occasionally, we'll have to go to that Check Switch screen more than once and re-set Tuner to 1 and then back all the way out againI can change to any tuner or any satellite transponder and it shows zero signal and zero lock... it was fine Friday night at like 10pm CST, then Saturday morning like 8am nothing....
Have they fired their network security person as of yet? This is just pitiful. I spent 8 years in a network NOC, and something like this is WORLD-WIDE call-out, and all hands on deck!SO we didn't wake up to a restored system, but were told Dish will start adding work orders this afternoon and maybe tomorrow we'll be working back to normal
Limited time offer
