R RidgeRunner SatelliteGuys Pro Original poster May 30, 2005 179 37 Raymond, Maine, United States Sep 18, 2024 #1 I have the LNBF only, I now need a scalar ring to be able to mount up to a 10 foot dish. Will any scalar ring fit? Or is there a specific one I need?
primestar31 SatelliteGuys Master Pub Member / Supporter Lifetime Supporter Mar 15, 2005 14,910 17,701 Beta Omicron Delta III Sep 18, 2024 #2 RidgeRunner said: I have the LNBF only, I now need a scalar ring to be able to mount up to a 10 foot dish. Will any scalar ring fit? Or is there a specific one I need? Click to expand... ANY C-band scalar ring that has a large enough center hole to fit it, will work just fine. The older thicker ones would be even better than the cheaper new thin ones, if you have around.
