OTHER - Cannot get Disequ 1.2 to move dish | SatelliteGuys.US
OTHER Cannot get Disequ 1.2 to move dish
tiredold
31
20
Greetings, I replaced my reciever on my Ku dish. I can move the dish with the onscreen east-west controls in the motor set up screen, I can also move the dish with my MP02 Stab positioner control. I can memorize the position. But the reciever will not move the dish on its own. I am stumped. When I change satellites, the dish does not move. Any help would be appreceated.
If using USALS to move your dish, have you entered your latitude/longitude coordinates? What receiver are you using?
Not using USALS. The box is a gtmedia v7plus. I cannot find anywhere to enter the lat/long. It worked perfectly with the last box, also a gtmedia v8, also on disec 1.2. I can move the dish with the box's move commands, and with my MP02, but the box will not move by going from one sat to another.
If you aren't using USALS, what motor (model number) do you have? That box can NOT move a C-band dish motor by itself. IF you have a USALS/Diseqc motor, there MUST be a place to add your local site coordinates in the satellite setup menu
I have a GT Media V7S5X. Maybe they are similar. For mine, once USALS is selected for Motor Setup for a given satellite, there is a green button command called Set Location that if pressed brings up a menu where you enter lat/long.
Reactions: freddylq
Maybe this also:
Menu / Installation / OK / 0000 / On left hand side of the screen, move Cursor down to (USALS Setup)/ OK / Put in your long / lat information / Exit out.
Maybe this also:
YOU WERE RIGHT!!. I never noticed the green button changing function. HOWEVER, still no love. Even when I programmed all the sats to USALS, there was still no movement initiated by the box, only by using my MP02 when in USALS mode. I am sure the issue is in the box. I ordered a new box and it will be here next week. In the meantime, I just select the sat and channel I want, and move the dish by the MP02 until the channel pops up. Not ideal, but it works. Thanks for all your help and happy holidays.
Reactions: primestar31
Does the coax from the receiver go DIRECTLY to the USALS motor, or is there a switch in-between them? The coax should go directly to the motor. IF you need a switch to switch lnb's, the switch should be on the output port of the USALS motor, then to the various LNB's.
Yes, rec to stab to lnb. Going to switch receivers and try.
You do have a STAB motor?
The STAB might be peculiar, as to what GotoX command it will respond. See USALS/ GotoX; Raw diseqc commands
You have tried with StorePosNn and GotoPosNn commands, when I understand you correctly?
I have had a symptom like this with my STAB, with a long, not-too-good cable. Have you tried with a short cable?
Greetz,
A33
Greetz,
A33
It is actually a SM3D12 by Multistar that is a clone of the Stab. I swapped cable (new one I ran just to test). I can move the dish with the east/west keys on teh rec. disec2 screen, but Goto X has no result. Same with changeing sats. So no problem from rec. to dish. Problem is in receiver. I will swap with another receiver to test, but I already have a new receiver coming from Amazon. Should be here next Friday. It worked last week with another receiver that I moved to another dish. Logically, it HAS to be an issue in the receiver.
Reactions: Keith Brannen
Not exactly a Stab clone because apparently it's only diseqc 1.2.
Which means you'll have to search for sats and store them to a position like big dishes.
How? Yeah.
Limited arc travel might mean it's time to swap for an SG2100. Then you'll get your usals.
Be certain that your longitude and latitude coordinates are entered correctly in the stb. Often the longitude East / West selection is selected wrong or not entered as a positive or negative number.
Please take a screen shot of the USALS (GoTo X) motor configuration menu settings.
Reactions: FTA4PA
Somebody post the english manual. My Google lens says that one button sets the current position and the other.....najjužnejšieho. Yeah!
I see text that says:
Please read the instructions for using the receiver regarding turning the motor to the left (E) or to the right (W), saving the satellite position in programs, and changing the satellite or program. The motor recognizes the following commands: 1. turning to the east 2. turning to the west 3. saving the correct position for satellite xx 4. searching for satellite xx 5. going to other or "home" positions (or searching for satellite 00) (you should search for satellite 00 whenever the motor loses position due to a power outage).
And:
Functions of the buttons and explanation of how they control the motor using E/W buttons on the motor (EEAST=east, W-WEST=west). Briefly press the E button, which turns the motor to the east by 1 step. By holding the E button, the motor will turn to the east as long as you hold the button. Briefly press the W button, which turns the motor to the east by 1 step. By holding the W button, the motor will turn to the east as long as you hold the button. E (east) = (východ) W=(west) = (západ) = short movement = short movement = long movement Rotation Rotation = long movement.
Andd....:
You can use this function only if it is also supported by your receiver. If you have the "GO TO X" function, you can ignore the section described in part M. This function does not require any programming. It operates with the following methods: receivers supporting any satellite (for example: ASTRA) based on your geographical latitude and longitude that you have entered, then the values set using DiSEqC communication via coaxial cable to the motor SM3D12. The motor, when turned on, rotates in such a way that it captures almost all satellites, depending on your location on Earth. It works under one condition, that all available satellites (e.g.: ASTRA) are pre-programmed on your receiver. The motor rotates to the satellite, you just need to find the satellite that is set in the receiver (e.g.: ASTRA).
More:
The satellite position settings are variable according to the receiver, so please follow the manual for the receiver that supports DiSEqC 1.2 or function. In the receiver, satellite positions are usually stored under a number (e.g.: from 1 to 30), so we recommend proceeding according to the logical sequence of the receiver.
A fellow here sent me a few broken Stab motors. At the most, maybe I can get one good working one out of them. At the least, get the guts working to figure out how these critters tick. Things like "who is 1 and who is 30" in the positioning and how they are stored in the motor baffles me. A Stab or three here is a lot better than one in Detroit, I'm sure we can all agree on that.
And:
Andd....:
More:
Did you also get the brackets with those broken Stab motors ?
Reactions: FTA4PA
WORKING!!!
As I suspected, the problem was in the receiver. As soon as I swapped the box, it worked perfectly. The only other thing I did was reprogram the limits. Anyway thanks for all your help.
GEOSATpro How temperature sensitive are Vbox dish movers?
AMIKO Amiko Mini 4k vs HD265?
