211k deleting recordings | SatelliteGuys.US
dmag
99
11
Eastern Pennsylvania
I've been having a recurring problem that I can't seem to find any information on. I have two 211k's and each one has an external hard drive. For the last year or so periodically both of the drives will not play any recording over a couple weeks old. They show up on the list but when I try and play them I get the " A problem was encountered when opening the files of this DVR event" "Please note error Code: 05". I know it's not a hard drive problem because I replaced both drives. I also swapped the drives out between the two receivers. It also happens on the same day for both. In other words I watch a recorded show at night, wake up one morning, turn on the reciever and it won't play that show or any other. I turn on the other receiver and any recordings on that one won't play.
I tried Dish tech support and all I got was "Oh Well", and they try and get me to upgrade to the Hopper. I know the 211k's are becomming obsolete but I don't want or need a hopper. I also don't want to get into a new contract.
Yeah - I had the issue starting back in October. I had a thread that I started that I can't seem to find at the moment about this. I am not sure why the VIP211k started deleting. In essence, the files for the recordings were deleted but the entry was not removed from the recording list. I lost about 7 years worth of recordings. And I know they were deleted because my hard drive showed something like 200 hours of HD space left, but I had a lot less and previously had to individually remove things.
Upgrade. That VIP technology is forgotten and abandoned.
I did look into that. The Hopper does have a lot more features, but it's mostly all bells and whistles that I don't need or want. And on the down side my bill would go up (I already pay over $170 a month) and I would be back under contract. I think, after 25 years of being a customer, it may be time to cut the RG6 cable and go OTA/streaming.
Reactions: charlesrshell
Then I take it you never found a solution.
Wallys are the direct upgrade for 211's but you'll lose the Ch3 Coax Output and the OTA input without an OTA USB Adapter
Correct. I ended up losing all my recordings from the past 7 years - multiple complete TV series and movies I would go back and watch. I started recordings again, and then once the recordings got to be about 2 months old, they stopped working. I find it hard to believe that both of my hard drives, on two separate VIP211k's, went bad at the same time. Coupled with the other users who reported the same error the exact same week I did originally, to me it seems like there was a change on Dish's end. What it feels like to me is that all recordings have a build-in expiration of some set time and then get auto deleted. I know that isn't the case, but that is what it feels like with what I am observing. There is probably something bigger going on.
At this point, I just have the recordings so I can catch shows that I miss when I am at work, or if there is something on at night and I need to get to bed early, I can catch the next morning - I no longer look at my DVR as a long term solution to save entire TV series or movies that I can pull up when I want.
Hunt around in the menus and see if there is a new option somewhere on how long recordings are kept
I looked at that but it wouldn't prevent my bill form still going up or me going back under contract, unless I buy the box's outright, and with DISH in it's current state that's a commitment I'm not about to make. And you are correct I would still need to buy the OTA dongles.
I think you are correct. I first noticed it on both boxes in the morning so I suspect it was an overnight software update. I was a little disappointed when I talked to the tech. I understand the line is going obsolete but he wouldn't give me anything. When I asked when they did the last software update he wouldn't even tell me. All he would say is I have to upgrade.
Well, here I am to rain on your parade. I have a similar problem with my H3 no longer recognizing some of my EHDs. No help from Dish. So you may move from one box to another but the problem remains. Sigh. :(
I might try to clone the old EHDs onto a new, larger EHD. Someone posted how here, using Linux. Years ago I was using Mint.
But is it worth it?
I might just give up on Dish and move to streaming. But that might put a grin on Bruce's face. ;)
Thank you for the suggestion. I did look around and couldn't find anything. I tried "protecting" a few of the recordings but that didn't help.
I think if got it
Is your hard drive mostly full?
AI Overview
Dish DVR recordings typically delete after 2 weeks because this is the default storage setting on most Dish DVRs, designed to automatically clear older recordings when the hard drive starts to fill up, making space for new recordings; you can usually adjust this setting in your DVR menu to keep recordings for a longer period if desired.
Key points about Dish DVR recording deletion:
  • Storage management:
    The primary reason for automatic deletion is to manage the limited storage space on the DVR, prioritizing newer recordings over older ones when the hard drive is full.
  • Customizable retention period:
    You can usually modify the storage settings on your Dish DVR to change how long recordings are kept, allowing you to choose options like "save for 1 year" or "save for a specific number of days".
  • Deleting oldest recordings first:
    When the DVR needs to free up space, it will typically delete the oldest recordings first.
How to manage DVR storage:
  • Access DVR settings: Navigate to the DVR settings menu on your Dish receiver.
  • Adjust recording retention: Select the desired storage duration for your recordings.
  • Manually delete recordings: You can also manually delete recordings you no longer need to free up space.
I think if got it
AI Overview
First I want to thank all of you for your help in this. It's funny, I'm getting more support from the folks here then the Dish tech rep.
Storage space doesn't seem to matter. I have two external drives. One is about, or was, depending on how you want to look at it, half full, the other one is almost empty. (When I first had the problem I thought it might be a bad drive so I installed a brand new one). And it doesn't actually delete them. Periodically it just no longert plays anything over a couple weeks old. They still show on the menu, but if you try and play you get the error message.
As far as management goes I don't think these 211k's have any thing for retention, at least not that I can find. And in the previous years that I had these it was never a problem , and there were times that I filled the drives up to almost the limit.
Sounds like dish is forcing an upgrade
That's what I was thinking. Either a DRM (digital rights management) issue, or DISH trying to force an upgrade.......but they will just end up forcing me to drop my service all together.
If they came to me and said we want you to switch to the Hopper/Wally and it would be for the same monthly bill I pay now without forcing me into another two year contract, In effect keeping me where I am now, I would do it. But, frankly it's not worth it to me to upgrade otherwise.
Not sure how it makes your bill go up and even so, it can't be by much.
Regardless, your 211s are VIP series receivers that have a soon-approaching end of life, and buying the Wallys outright isn't a commitment. There's no contract and you could re-sell them if you leave Dish
DVR fees and, of course the one time cost of the OTA dongles. I'm not saying it will go up tons but I consider it an unecessary increase.
You are correct in that buying the Wally's will not require a contract. By commitment I mean buying hardware that may be a brick depending on what happens to DISH in the next couple of years.
Wallys don't have DVR's and your EHD can be transferred from the 211's to the Wallys
You can still lease them and talk your way out of a contract...
Other than the ota adapter one time fee your bill will stay exactly the same.
If you did want to buy them it would be $100 up front but would save $4 per month. Then can turn on and off as needed or like mentioned sell them later on if you don't need them anymore.
Drama and Classics Pack?
HITF do I stop dish from recording a series!?
