Can you change the four channels shown on News Multiview 201? | SatelliteGuys.US
bookworm370
1,212
1,050
Columbus, Ohio
Multiview always picks the four channels that, I'm sure, those who know better always show. A couple I like, a couple I really don't give a sh(a)t about.
Are we stuck with 2 or 3 channels that we have to tab through all the time to get to the one we want, or is there a hidden magic way to change them or even just go to 4 channels if they are pickable?
If not, maybe this can be submitted to Dish Support to maybe be put on a list?
AFAIK it's not assembled on the fly, there's actually a channel transmitted that looks like that.
If you have an H3, you should be able to make up your own selection in sports bar mode (I would think; I don't have an H3.)
Whenever I had my hopper 2000 on service it did not allow me to, but as the previous commenter said, it may be possible on a hopper 3?
Reactions: charlesrshell
The Hopper 3 does a FOUR channel pip.
That's four at 1080 each on a 4 K screen.
Hey!! I found it, but it was buried in Apps, so I cannot access it directly. But ho hum, that's for another time.
Now, how the heck can I change (again) which special channel the gods at Dish decided that I want to watch? It shows "Free Preview Showcase" which I take I can't change any channels! Only the ones they want me to buy!
There are also Sports Multiview and News Multiview, but again, you can't change those channels, even on Sports or News channels.
I have tried every button on the remote, including just typing in a channel, and nothing works to change the channel. What am I missing??
If I select a channel and press select, it goes full screen, and I cannot get back to the 6-screen view unless I work my way back to the APPS section. Then again, only those six channels are available.
See below. Do you have any ideas how to change the channels? I'll even put up with the 'Cannot get back to multiscreen issue,' but I would like to monitor the channels that "I" want to monitor.
Thanks in advance if I missed another selection or option.
Press the PIP button on the remote
The DISH channel is not changeable
Again the DISH channel is not changeable
Input button as swap tuner button
