Does the site at gjullien.fr/satellite.htm still work for anyone? Wanting to use the moon to find a satellite | SatelliteGuys.US
ancient
441
229
USA
The site at Place satellite dish using sun or moon used to allow you to "use sun or moon to choose the best place for your satellite antenna." While there are (I think) other sites that will let you use the sun, that was the only one I knew of that would let you use the moon. It used to display an animation of the globe, with the relative positions of the sun and/or moon and a satellite (as viewed from a specified location) shown. The site is still there, but I think the problem was it required Java, which almost no one uses anymore. So we set up a VM and installed Java but it still does not seem to work, and I wondered if it still works for anyone. It will still let you enter your coordinates, but for me it then just sits there doing nothing, and the globe animation is never displayed.
The main reason I am interested in this is that the sun can only be used during spring and fall solar outage times, but the moon tends to get near any specific satellite several months out of the year (hopefully during nighttime hours). Are there any other sites (or desktop applications for that matter) that let you track when the moon will be close to a specified satellite as viewed from your geographic location?
Reactions: Corrado
It works for me just fine in Firefox. However, click the box and read this post I made a month ago:
Why Do Satellite Receivers Scan as they Do?
Questions about the PBS mux on 99 KU
