Is the V9 programmed with N.America sats? Is there software/hardware support?What channels have you verified the CC to work on the V9? You can PM me if needed![]()
Just received mine yesterday. It is programmed with satellites from 3E through 108.2E and 61W through 0.8W. I just save this to a USB memory stick as my Europe list then start editing it using the remote control as I scan each satellite that I can receive. It's not so difficult.Is the V9 programmed with N.America sats? Is there software/hardware support?
Since you ask, I had to try! Listening to WPR Classical on 99W Ku. Locks it solidly while using my Invacom QPH-031 LNB. It does take several seconds to lock in, but once locked it's solid at SQ 81%. Nice station; first time I've ever heard it. What's the lowest SR tp you can throw at me?Tried to lock any low symbol rate feeds yet?![]()
Have you had luck using this editor for V9 Prime? I edit using it, then try to write from USB stick back into the V9 Prime and I keep getting "Invalid file". All I'm trying to do is arrange the satellites in my preferred order using the editor. I did all actual editing of the database using the remote control.Here is the appropriate editor for the V9 Prime:
Limited time offer
