Edision OS Mio+ TNAP 5.1 Service Reports | SatelliteGuys.US
cyberham
6,102
5,141
British Columbia
Can anybody point me to where the Service Reports are located? These are created each time you run a blind scan and stored. I used to refer to them but I can't find them anymore.
Register to hide this ad
I did find some blind scans from today there. Thanks. Do you know where they are moved to since /tmp sounds temporary?
by default they are not copied and just get erased whenever you restert the box. However if you have a connected usb drive, create a folder in it named "ServiceScan" (make sure the spelling and case is correct), then the service scan logs go in there are are preserved. As far as I know, the blind scan logs (that only list the transponders, but not their content) still go in /tmp and are lost upon restart
of course the logs in /tmp can still be saved to a PC thru the network if you don't have a connected usb drive
Works like a charm! I recall reading this before from el bandido but I can't get into his site now to research. I had to recently reformat my external hard drive so I lost all the Service Reports history. Creating ServiceScan now allows them some place to be transferred to.
TNAP 6 for Edision: Yes or No?
