Software Versions for Android TV (ATV) devices - Joey 4, Wireless Joey 4, Hopper Plus | SatelliteGuys.US
Almighty1
1,556
1,463
San Francisco, California USA
As of the time of this post, these are the latest software versions for the following Android TV (ATV) devices:
Joey 4 P53301
Wireless Joey 4 P63301
Hopper Plus P13301
I upgraded my Hopper Plus from P13113 to P13301
Register to hide this ad
As of the time of this writing, these are the latest software versions for the following Android TV (ATV) devices:
Joey 4 P53305
Wireless Joey 4 P63305
Hopper Plus P13305
I just upgraded my Hopper Plus from P13301 to P13305
This thread is to keep updated on the software versions of the devices in question and not the main receivers which would be in their own thread(s).
Reactions: charlesrshell
Not sure what is the version number that add PIP to them. :) But it is rolling out now.
PIP? That's a good thing, now they just have to bring back Multi-View. The Hopper Plus update did fix the issue I had with when using DISH 50.0 & 52.0 remotes turning on and off the TV with the TV Power button while other remotes worked fine when the TV would power on with DISH Scapes instead of the last tuned channel that P13712 had as mentioned in the H398 thread. I thought it fixed the weather icon but apparently not.
I take that back, the same problems are still there.
Still waiting on the new software . . . . is there a trick to getting the update or we just have to wait it out?
You have to manually update it or wait until it downloads and installs on it's own.
Updating manually on the Hopper Plus,
1) Hit Menu on the DISH Remote
2) Click the Cogwheel (Settings)
3) On the Settings Menu, select Device Preferences
4) On Device Preferences Menu, select About
5) On the About Menu, select Software Update
The Joey software is downloaded / stored and served from the Hopper. When the Joey's get a software update they get it from the Hopper.
Thanks for the reply. That menu is in the Joey's, but when checking for the update, it says it is current. Since this is a phased rollout, (PIP, etc...) I guess I'll just get it when I get it!
What’s going on with KWCM (Pioneer PBS) in the MSP DMA?
