Just a brief aside. Since the remote controls for my GT Media V9 and V7S5X receivers interfere with each other as they transmit common codes, I just arrange to have one unit powered on and the other unit powered off. Then when I press the power button on either remote control, this turns one unit on and one unit off. This way I can use both receivers without unplugging one of them and I only want to use one receiver at a time anyway....so if you cover up the IR window on the back of the remote, it won't interfere with your other GTMedia receivers![]()
Curious - what version of the AliEditor worked with this V9 Prime box?OK, I was able to add the music channels using the AliEditor. Thanks for everyone's help.
I'm using DB4 3.3.2 2021-4 Upgrade Library Version 3.0.0e. It is called Ali DB Editor Release and dated 20220512.Curious - what version of the AliEditor worked with this V9 Prime box?
They shouldn't, because they are paired to their respective receivers. So, most likely will have different codes when you pair them. Or if they do out of the box, you can RE-pair one of them.Any Bluetooth experts here? Thinking about picking up another GTX Combo, this one for KU, but not sure if the remotes would conflict since they're bluetooth and not IR?
Not an SSD. Regular Hard drive. Solid State doesn't have an RPM speed.It will be fine though.For anyone who wants to buy an internal SSD for the GTX Combo, this is the one I bought, and it is guaranteed to work (thanks to the Youtube guy who did all the testing).
$33
Can the GTX record ABC and CBS 4:2:2 feeds and then play them back using VLC but can't view them live at normal frame rate?
Limited time offer
