Heres my results:
Network Affiliate Channel Status
ABC WHSV 3 Grade B (moderate signal)
CBS WUSA 18 Grade A (strong signal)
FOX WTTG 46 Grade A (strong signal)
NBC WVIR 28 Grade A (strong signal)
PBS Eligible
Digital (HD) Distant Network Service
Network Affiliate Status
ABC WHSV-DT Grade B (moderate signal)
CBS WUSA-DT Grade A (strong signal)
FOX WTTG-DT Grade A (strong signal)
NBC WVIR-DT Grade A (strong signal)
CBS and the Fox station towers are 108 miles from my house--this is one of the reasons I dumped D* after more than 8 years service. When we moved from NOVA we intended to keep D* but after 6 months of run around and being in the suspend mode,D* said that they (I) could not get the waivers so I canceled. For the hell of it wrote the stations and got the waivers,oh well D* guess you don't need my 1500.00 a years
Checked D* for sd and HD DNS. I'm 56 miles from the Madison WI towers. NO DNS SD or HD because they are available via D*. Don't really need them as I get 100% OTA HD signals and get SD either from D* or OTA.
Two things you absolutely missed:branchbouncer said:CBS and the Fox station towers are 108 miles from my house--this is one of the reasons I dumped D* after more than 8 years service. When we moved from NOVA we intended to keep D* but after 6 months of run around and being in the suspend mode,D* said that they (I) could not get the waivers so I canceled. For the hell of it wrote the stations and got the waivers,oh well D* guess you don't need my 1500.00 a years
Yes, if your HD locals become available on satellite, then you lose the distant HD feeds when they become available. This is what compounds the issue about distants: when analog locals go away, so to analog distants, leaving only the distant digital provisions of the SHVERA.ArtWIS said:Checked D* for sd and HD DNS. I'm 56 miles from the Madison WI towers. NO DNS SD or HD because they are available via D*. Don't really need them as I get 100% OTA HD signals and get SD either from D* or OTA.
The OTA would be better than anything D* could re-transmit to you plus they are free
I can't compare D* HD locals to my OTA HD locals because I haven't upgraded to the MPEG 4 receiver and AT9 dish yet. But my OTA HD locals look great. I find that all the HD I do get from D* looks great on my Sony and I'm looking forward to seeing what they do after the 2 new birds go up.![]()
But once again, there are mistakes about the law...Two things you absolutely missed:
1) WTTG and WUSA are not 108 miles from your house. There are translators in Harrisonburg, a mere 15 miles away.
2) Waivers must be requested by your provider, not you.Yes, if your HD locals become available on satellite, then you lose the distant HD feeds when they become available. This is what compounds the issue about distants: when analog locals go away, so to analog distants, leaving only the distant digital provisions of the SHVERA.
So, this means every time a new market is added, there will be many people that lose their distants.
And Dish Network no longer has the right to do digital distants. The only way people will be able to see network HD on Dish Network is if they uplink all the markets.
Heres my results:
PBS Eligible
The problem is that the qualfications for "digital distants" are the exact same as "analog distants". Pay attention to that last sentence, because it will be mentioned again.
If you can receive the analog versions of the networks, you cannot receive the analog nor digital distants.
Limited time offer
