Can a 5 lnb be mounted on the side of a house where a current 3 lnb is? I have many friends who have had new 5 lnb dish placed on their roof. Any pros and cons to either?
Thanks, Its vinyl siding. I guess I'll see what the installer says.
I had them mount mine above the Overhang so if it did leak it wouldn't go into the house. But I do have a 2 foot eeve.
Most eves are not heavy enough for the 5 lnb due to it's addl. weight.
I think he means on the roof, but over the overhang of the roof, so that if it leaks it will not go into the house.
So the fascia or rake board
No, on the roof itself, but over the overhang. The fascia isn't strong enough to support a dish of any size without compromising the fascia board without additional support. A rake board is different, as you can lag into the end roof rafter.
Thats a pretty wide rake board your using ... the footprint of the mount in like 7-8"
Jimbo
Limited time offer
