I can't answer for Garys but I have a Dishplayer 7100 connected to a DPP Twin it is a Legacy receiver and works with no problem.have you done this without a DP reciever hooked up??
thanks
Will Legacy receivers work with a Dish Pro Plus LNB with no DP receiver hooked up??
You sound like a DISH trained installation technician a90 day wonder that really knows nothing about the products. A Legacy LNB used switching voltage to change polarity either 12 volts or18volts so how can you say Legacy "can't push the 18 volts required to run the switch."Yes you can hook a dishpro reciever to a leg switch, the reason you can't hook a single leg reciever to a DPP LNB is because the leg rec can't push the 18 volts required to run the switch. Thats why you need one dish pro reciever to give the extra voltage. Now if you want to use a power inserter from a DP 44 switch, you could do that and that would let you run a leg reciever off a DPP.
You sound like a DISH trained installation technician a90 day wonder that really knows nothing about the products. A Legacy LNB used switching voltage to change polarity either 12 volts or18volts so how can you say Legacy "can't push the 18 volts required to run the switch."3 of us posters have stated we are doing it successfully.
Bob is right that the legacy receiver can push up to 18v but the DPP Twin needs over 20v. I believe it's 21v or 22v. The Legacy receiver can push over 18v but it's overworking, running the risk of burning out.
If it's working, great. But I wouldn't push my legacy receiver.
The reason I posted the PDF file was because it's not approved by Dish Network. They recommend a Dish Pro receiver must be connected to provide enough power. I would assume that they tested in their labs before making such statement.
Birddoggy, Randall A, Smity Whity and especially Claude Greiner you are all hung up on 18 Volts. As I posted earlier the Legacy switches polarity by voltage switching. Legacy uses both 12 and 18 volts so the voltage has nothing to do with a DPP working with Legacy receivers. DP does band stacking so only 18+ volts is used Legacy switches voltage instead of band stacking so a DPP Twin will work with only 12 volts getting to the amplifier.
Limited time offer
