If you have never connected a cable to it, then odds are that it is still working. The weight of the cable hanging from the connector is believed to be a contributing factor to the failure.
For DVD players, I'm looking at either Sony DVP-NS75H or the Samsung HD-860. The TV is Samsung 6187W. I know the TV will accept 1080i over component. Ideally I would like to run the upscaling DVD over component as that is how my home theater will best accept digital audio input.
DVD players will not uspscale over component unless the disk is not encrypted(which is rare). Must use HDMI for that. Look into the Oppo also for upscaling. Many people are very pleased with it.
S~
Yea, after doing a little more reading and research, I'm learning that component+progressive on a DVD player is only going to give me 480p at best. Since DVD quality will never be better than 480p I think I'll stick with the progressive player I have and hook up the 622 and the MediaLounge 520 to the HDMI inputs. I've already started to find some HD content on the internet that I can play on the MediaLounge. That video quality is stunningly clear and crisp on my Sony 36" SDTV so I can't wait to see it in HD.![]()
I've got one of my 622's hooked up using both the component and HDMI as both outputs are active at the same time. DD5.1 is not active over HDMI output at this time on the 622 (scheduled for sometime this year). The component and optical run to my receiver, the HDMI runs to my TV. I run my HDDVD player and BR player into the receiver through HDMI.
S~
DD5.1 not active over HDMI?!? What the hell were they thinking?
You must have a receiver that does HDMI switching...I unfortunately don't. I can do component switching on DVD and "Video 2" but that's it. I also have a limited number of digital audio inputs...so...
Although they say they use HDMI specs, they don't. Look at the name of the connector. It says HDTV not HDMI.
Not everything needs 5.1.
S~
Actually, the Bravo D1 has a code you can key in to turn off the Macrovision and allow upscaling. They have a fresh crop of them at NewEgg for about $35. The D1 also allows for pixelmapping over the DVI port to the native resolution of your HiDef display - perfect for projectors.
Does anyone have a source for the repair of the HDMI problem with the 211. I have no warranty.
CNC9130
Well, I finally called Dish again last week concerning my 622's dead HDMI port (worked fine for several months before going completely dead one day). The last time I called (Oct last year) the CSR insisted that a software patch was being worked to correct the HDMI problem and that I should wait. The CSR I talked to last week didn't hesitate at all and shipped out a replacement 622 right away - arrived 3 days later! So, problem solved. I'm now glad I chose to lease rather than buy - had I bought mine it would have been out of the 1 year warranty window. Anyway, problem solved. No more dead HDMI port!
Cheers!
--Supercharged_Z06
Support that cable at the back of the receiver. Don't let it droop. That downforce could be a lever, causing the connector pins on the PCB board to lift....I have a projector and need to run a 30' HDMI cable to the receiver. That cable was not cheap so there is no way I am going to a component cable. It wouldn't be cheap either. The CSR said they know this is a situation but said nothing as to their remedy. Maybe they think we will all give up and live with a broken receiver.
Limited time offer
