I've been have trouble with my HR20. A box keeps popping up saying searching for sat 1. I'm on my third receiver, Directv sent out a "HDTV specialist" twice and I'm still having the problem. Has anyone else had this problem and had it resolved?
I'm not sure which multi-switch was used, but I'll go down into the crawlspace under my house tomorrow to check it out.
The thing is, for three weeks before I got the HR20, I had a new Directv HD receiver (non-DVR) hooked up to the same HDTV and never lost the signal in Line 1 even once. Therefore, I don't think it is the 5 LNB either.
So, yes, it's likely it could be a problem with the multi-switch, but my thinking is it is probably a faulty HR20.
If you had an existing multiswitch and the installer did not go into the crawl, then I would suspect that to be a good possibility of your trouble.
I personally would not have a multiswitch in the crawl, must be a pain to get too.
Jimbo
Limited time offer
