IF you are doing the forced updates (Beta testing) that alot of us are doing, then yes if you were to force an update now, you would go back to the National update, which at the moment is the same as the one that the Beta testers are using.
So currently you would not go back to anything other than what your at already, but it could help if you are having issues.
