need to transfer from vip622 to vip622 | SatelliteGuys.US
jldesign
17
ok our great vip622 cr@pped out the HDMI does not work. I have a return auth number and a new unit on the way. we have hours of shows/movies I need to keep. can I transfer from one vip622 to vip622 the dish folks are far from helpful at times.
all i want to do is not loose our recordings.
they are saying bad old software updates are the cause of hdmi signal loss
please save me from my wife all her shows are on this thing!!!!!!!!!
j
Sorry, but I think you are pretty much out of luck.
If you have a DVD Recorder, you could burn the shows to disk, but you would need to downrez it to 480.
Or you could use the existing 622 with component video until you watch the shows you want to see. But there is no way to transfer programs from one 622 to another; at least not until the External USB support comes out... maybe this summer.
Will external USB allow you to transfer between machines? Cable Boxes with external HD will only play on that machine.
wat about the idea of hooking up his hdd to his comp and copying the programs like they do with the 5XX series... check out dishmod at http://tech.groups.yahoo.com/group/dishmod/
maybe a pocket dish as well, copy then over from one reciever to the other, may or may not work, im throwing out ideas
Good Morning All,
I just wanted to provide an update on this subject, as I have
been viewing the posts for some time now and tried it for myself
recently.
I was successfully able to extract most of my video content from
my VIP622. I used the procedure that most had stated previously:
1) Move 622 near PC (with cover removed) and power up.
2) Run "Ext2 Installable File System for Windows".
3) Unplug SATA cable from DVR and plug in SATA cable from PC
motherboard.
4) Run PVR Explorer Pro.
The only issues I ran into while performing the rip were:
1) The vast majority of the video files weren't recognized properly
by PVR Explorer Pro.
2) Some of the files weren't discovered at all by PVR Explorer Pro.
I was required to play the newly created files and rename them
manually after the rip was completed. This was a small price to pay
(initially) to be able to clear out my 622's HD, but will get more
annoying as more rips are performed.
Almost 20% of the video files weren't discovered by PVR Explorer
Pro. I didn't delete these files after the 622 was reinstalled, in
hopes that I may be able to rediscover these files after the other
files have been deleted.
Items of note:
1) I have a 1m SATA cable running from my mb to the 622 HD. No need
to make things more difficult by adding another interface in the mix.
2) I'm going to try to make this easier to perform by adding a SATA
connector to the front of my PC so I don't have to open it up or have
a cable hanging out the front.
3) I'm also going to have a SATA extension cable and connector
hanging out the back of the 622 so I don't have to crack the cover.
In conclusion, I believe this method is serviceable at the
present time. I truly believe that (as a software developer myself)
the only issue remaining is with PVR Explorer Pro. It is very close
to being an excellent solution for the dishrip community. I didn't
detect any bugs and it seems to be a very robust application. I have
used software in the past that has balked at the thought of creating
a 20GB file. PVR Explorer Pro did not! Since all of my files are mpeg-
2 (even the ones recorded at 1080p), I can't comment on it's
abilities with mpeg-4 files. I believe this is another issue that the
folks in the PVRExplorer group are discussing. My hope is that these
issues will be resolved by the time E* starts broadcasting most of
it's content in mpeg-4. So, until then, I will continue trying to
refine my current method of extraction and pass along any new tidbits
I discover. Good luck and Good ripping.
THIS IS NOT MY WORK C/P!
Dish 1000, 1000+ and Dish 1000.2
Upgrade from Dish SD to HD?
