Junk or treasure, GI650i | SatelliteGuys.US
Comptech
3,672
2,834
Travelers Rest SC
Found this reciever in the garage of a house I bought.I cannot find the remote. My question is if I use the the loop through on my coolsat 500 so i can control my 1 meter ku dish is there anything this reciever will pick up on the ku band?:confused:
:welcome to the forum
the GI 650 is a C / KU receiver for big dishes, its probably the top of the line GI made before going to the 4DTV series receivers. A 1 meter dish might be on the small side but several folks have played with a 1.2 meter dish and c band signals. I feel you would need a larger dish and a c band lnb or lnbf.
Remotes can be bought off auctions sites or a member here might have one.
over in the c band forum most of use use the receiver to move the big dish and slave the coolsat to it.
Its a good find for another way to enjoy this hobby..
Still using a 650 for cband analog. Great dish mover too-but you need a remote to get the sats programmed in. If you don't find a good remote for it-I have an extra (old) one that works, but the mute button is broke on it, all works other than that button.
Its called a GI IR/UHF Anywhere remote, works a 550 and 650 models.
You could use it for the KU analog with a 1m dish, if your other box will move the dish.
you vcan use it for KU too but without the remote itr can be tough. I use a Toshiba TRX-1420 for KU analog. Not a lot of feeds on there now but come fall when football starts back up there is a lot :)
So I guess it is strictly a anolog reciever.If so that is fine. Does it have any scan features or do you have to add sats and tp's manually?Just wondering if it is worth buying a remote for it since all I have is a Ku dish. Also does anyone have a link to a manual for this reciever,can't find anything from google. Thank again.
correct
other than SBS6, analog has one set of numbers for KU. Each channel is 20k apart
Channel 1-11720
Channel 2-11740
Channel 3-11760
etc
polarity is not needed as the DVB box will control polarity
for the "manual" (or hoe to program in satellites
www.satellitehelp.com
Thanks guys,dvb is a piece of cake to me,but this is a whole new world and a new learning curve for me.Wish me luck! I'll be back with more questions I'm sure!
actually analog is pretty easy. On my Toshiba, I have 2 satellites logged in
SBS6 for SBS6 (duh!)
Galaxy7 for all others. G7 is the first one I found.
After making sure the frequencies were right thats all you need. Go to a satellite and check to see if any signals are there. On AMC2 (85W) there is a test card on channel 24 Vertical (I think on polarity). Its fuzzy but there :)
the manual for the 450 is in the manual section its close for the 650 just the 650 has a lot more bells & whistles. i suspect it will walk you through the basics just might not cover everything.
I own a 650 and have had many years of reliable service. The tuner is very sensitive and the picture quality is extremely good! The RF remote is a great feature for feeding programming around the house.
It works very well along with a DVBS receiver with the LNB selection for mechanical polarizer control or voltage control of a LNBF!
Just wish that they had a firmware update with current satellites ....... Anyone?
I also have a GI 650, I have it slaved off of my Fortec Mercury II. I have it hooked to KU only.
I still find it amazing to see a pure analog picture and how good it looks! Almost looks like HD when you look at all the compressed digital crap we have now!
You can get a remote for it at Skyvision.COM, the price is a little high but well worth it. If you are a sports fan or a news hound you will enjoy the 650 a great deal. :)
Coolsat 8000 Channel Editor
coolsat 6000
