M Mr_J Member Original poster Apr 17, 2007 12 0 Apr 28, 2007 #1 I have a few questions about "Over The Air" broadcasts and dish receivers. A 622 receiver will record OTA broadcasts. Will a 625? Can you record from cable TV instead of using an antenna? Thanks, John
RoyW SatelliteGuys Family Nov 19, 2003 77 0 San Diego Apr 28, 2007 #2 Mr_J said: I have a few questions about "Over The Air" broadcasts and dish receivers. A 622 receiver will record OTA broadcasts. Will a 625? Can you record from cable TV instead of using an antenna? Thanks, John Click to expand... You cannot record OTA with a 625 receiver, and no its not possible to record cable TV with a 622 ether.
G garys SatelliteGuys Master Sep 29, 2005 7,621 37 Greentown, Pennsylvania, United States Apr 28, 2007 #3 The 625 will also allow ota and cable signals to pass through to the tv tuner, the 622 does not.
webbydude SatelliteGuys Master Feb 6, 2005 5,339 1 Akron, Ohio, United States Apr 28, 2007 #4 garys said: The 625 will also allow ota and cable signals to pass through to the tv tuner, the 622 does not. Click to expand... To further elaborate, the 622 OTA can show up on the program guide, the 625 will not.
M Mr_J Member Original poster Apr 17, 2007 12 0 Apr 28, 2007 #5 garys said: The 625 will also allow ota and cable signals to pass through to the tv tuner, the 622 does not. Click to expand... Does it pass the signal through to both TV1 and TV2? Thanks, John
G garys SatelliteGuys Master Sep 29, 2005 7,621 37 Greentown, Pennsylvania, United States Apr 28, 2007 #6 Mr_J said: Does it pass the signal through to both TV1 and TV2? Thanks, John Click to expand... On the 625, using coax, I believe it should pass through to both sets (but am not 100% sure on this). If you use composites or s-video, it will not pass through to either tv1 or tv2.
J Jared Twomey Supporting Founder Supporting Founder Mar 7, 2005 2,066 0 Tacoma, WA Apr 28, 2007 #7 garys said: On the 625, using coax, I believe it should pass through to both sets (but am not 100% sure on this). Click to expand... Nope, TV1 only
