Added a D500 today to my 1000.2 for 129 | Page 2 | SatelliteGuys.US
what is the skew on your 1k.2? thats insane. here in mn its only 114ish and i thought that was a lot. you should get a wood 4x4 or 6x6 instead of the pole if you're doing a 2 dish solution. and why not go to a 500 w/ a dpp twin instead of messin around with the 1k.2?
Skew is 128.
The pole is plenty sturdy and was already in the ground so I used it.
I had the Dish 1000.2 first, then bought a 500 for 129. Why would I buy another 500 to replace the 1000.2 when I already owned it?
Nice pics.
Highest numbers I had on 129 was with a 90cm w/ Invacom LNB. They were in the 110-115 range. Not a very economical installation though ;)
Vip222 Bsod
FIOS, Cable Capacity Question
