Is it possible to have 91w, 97w and 123w on a 75e dish? I know 91w and 97w are possible, but how far can I go from 97w torwards 123w on this dish?
Well.....I've got 14 deg seperation right now on my 75e (channelmaster). IS-9 and AMC6. Its focused on IS-9 with AMC6 offset. It works pretty good.
Should work, you may need the tiny LNB's like SatelliteAV sells to get the centerline spacing for 6°.
Bob
6 deg spacing should be fine. The prob you will run into is the LNB itself blocking you from fine tuning. Smaller LNBs (as suggested above) should help you out in that dept. I had 74 and 79 on the same dish and that was my biggest prob. If you are going to go with 103, remember the weird skew for the H pol.
Not really sure. Since my Dish has a skew setting, should I be concerned with skewing the LNB?
I succeeded in installing 91w and 97w yesterday, but for the life of me I could not get 103w. I got signal from 105w, 119, even 101w, but not 103w. I tried twisting and angling the LNB but nothing on 103w. Oh! BTW my 75e globecast dish measures 36"X27". My location is North Lat:42.12 and West Long:71.04. Based on my location what should be the skew on 103w? How do i know if the skew on the LNB is right without having the do trial and error?Yes, you will have to skew the LNB as well as it is really off from what it should be. I have 91, 97, and 103 on one dish (pictured below left to right, plus Echo8 at 110). The skew for my area is 10.5 (91) and 16.5 (97), and as you can see 103 is in the minus!
Thanks Ice!Here is a great picture of what I am talking about
The farthest left LNB is on ANikF1 for StarChoice and the skew is right...the LNB to the right of it is AMC1...look at the skew (technically on the T90 dish the LNB's should be on the 0 spot on the holder...the LNB for AnikF1 skew is probably off by 2 degrees of zero or so
(by the way...disregard the 3rd LNB skew...that wasn't hooked up at the time)![]()
Thanks Ice!My LNB Angle is 30.3. Using your clock analogy, what dial on the clock should i be looking at?
This site, from one of the companies using the satellite, gives an adjusted skew for AMC1 for cities in the US and Canada:
Microspace - Pointing Info
However, I found that their adjustment (about -15 for my location) was not enough, and mine is at least -25 (or more).
Another factor, since you are using an elliptical dish, you already have the dish skewed for G25 (97). Skew for another satellite is based on a plumb vertical line from the ground. If your LNB holder has been tilted so that its zero mark (if there is one on the LNB holder) is also skewed, then you have to minus the skew of G25.
In other words: skew for AMC1 minus skew for G25 equals skew from the zero mark on the LNB holder.
Thanks for the info. I am still a little bit confused about this logic. I may have to read/research more on this. Meanwhile, i would appreciate more info.
Thanks Keith Brannen. As soon as I get the opportunity, I will try this approach and will keep you updated.I'll use my numbers for 91, 97, & 103 (and assume that 103 was not a wacky skew, but as it should be) to try to explain. Therefore the skews would be 10.5, 16.5, and 21.9. If I had a bracket for the LNBs that ran parallel to the wide part of the elliptical dish, the top of the LNB holders would be zero (and be marked as zero). As soon as you skew the dish to 97, or 16.5 skew, the zero mark on all LNB holders is skewed 16.5. The LNB for 97 remains at the zero mark as that is its correct skew. 91 skew is only 10.5. Therefore, to skew it only 10.5 you have to skew it -6 from its zero mark (10.5-16.5). For 103, you would have to skew it 5.4 from its zero mark (21.9-16.5).
Hope that helps (and doesn't add to the confusion).
Limited time offer
