Seems as though they don't want you to buy one...no way to do it on the site.
I already did that earlier in the thread.
If you look at the WD page again, they contradict themselves. At the top it says, 60, at the bottom, 30. My guess is the bottom is an error and probably refers to their 320GB drive. All in all, a pretty poor website.Yes, I wanted KAB input. More of what he likes vs dislikes. This is a good thread, I suspect we will all be buying within a month. Let's look at many options.
Odd, that WD lists capacity up to 30 hrs of HD video. Earlier it was posted that OTA HD 1080i would approximate 10GB per hour. Pretty big difference. Wouldn't you expect that this thing could hold at least 60 hours of Dish HD?
I'm leaning toward this drive after checking the Scientific Atlantic study. If it does not perform as expected, I can always find other uses for it.
Western Digital Caviar SE 16 WD5000AAKS 500GB 7200RPM 16MB Cache SATA 3.0Gb/s at ZipZoomfly
Best price I've found so far.
Ship makes it the same as Zip and a few others.Check Pricewatch - I see 99.00 for the drive currently.
That's almost same disk what selected by AT&T and 2WIRE for 622HZ.<skip> If it does not perform as expected, I can always find other uses for it.
Yep. the"JS" is 8MB Cache, the"KS" is 16MB, better yet.That's almost same disk what selected by AT&T and 2WIRE for 622HZ.
OTA HD clocks in at right around 10GB/hour for 1080i channels.
Dish will be somewhat lower than this due to MPEG-4 encoding on a number of channels and other factors (here we go again!).
Cheers,
John:
I've seen that 10GB/hr kicked around before, but if the 622 ship with a 320GB HDD, and 1/2 of that is reserved for Dish on Demand (or whatever it's called), that leave 160GB (i.e. 16 hrs) for recordings...yet it holds 30+ hours?!?
Am I misquoting the size of the HDD in the 622? Or does Dish programming only take appx 5GB/hr for MPEG-2, and less for MPEG-4, -vs- 10GB/hr for OTA?
Thanks!
I'll give it a mild "so-so".There really is no need to keep your eye on a thread. Go to dealmac.com - Find the lowest prices on iPod, iBook, PowerBook, Mac, eMac, PowerMac G5, iMac, News on Apple Mac prices. and you can register and tell it what you are looking for and they will search the web day in, day out and everytime the search engine finds a deal, it e-mails you and lets you know the details.
What I usually do is purchase and IDE 500gb hard drive and then purchase a USB case for it and your good to go. Its a cheap way of doing it.
Limited time offer
