Signal rate does not mean much, what you want is a high quality level.
What receiver are you using?
What size dish are you using?
Also I believe that 11972 H 8.417 is on 83 Degrees West not AMC 5.
Use 11741 V 11110 or 12181 H 23000 which are on AMC 5.
I have the right satellite now but the signal stays on 10% and jumps 99% frequently I simply can't get it to stay on 99%. I've done a lot of tweaking to no avail.you're at the wrong satellite...
AMC5 has 2 strong transponders
11742 V 11110 (freq, pol, symbol rate)
12182 H 23000
Yes I have set it up to be Standard 10750.well lets ask the obvious...I assume the LNB LO is set up right? According to the equipment in your sig, the LNB LO should be 10750.
I get Kuen-tv and Sinclair, Cat1-6, Programoh ok
try a smart scan...let it scan all and see what channels come up. Then we can tell![]()
I'm using a Motor dish with Invacom LNB. Is there any other 10750 sat that I can try? I'm getting Picture on Kuen-tv but the signal is too weak.Have you tried playing with the LNB skew, dish azimuth, dish elevation?
Also are you using a motor or a fixed dish?
Limited time offer
