015 acquiring satellite signal -- 2800 model | SatelliteGuys.US
cruiser1one
3
I just got an Echostar 2800. Hooked it up to me DTV oval dish (one with two dual lnbs). First thing after I turned it on was to see the 015 "acquiring
satellite signal. Is the reciver broken? If so, what would i need to repair to obtain a signal.
Thanks for any help
using a dtv sat dish that has two dual lnbs with 4x multiplexer
hooking 2800 receiver to it. worked great with a dtv receiver.
First DISH is not compatible with Directv switches so eliminate the 4X. You also need to reaim the satellite dish to look at DISH Networks satellite your Directv dish is pointing at a satellite located at 101 DISH uses satellites at 110 and 119.
got a dish 500 w/legacy lnb & a 2800 receiver
can't seem to get any signal
receiver works with my old dtv dish/lnb
am I overlooking something in setup of receiver??
any help appreciated
