Unfortunately, I would recommend driving the truck to the dump to unload. Now that the damage is done, in my opinion, it's not worth the effort to repair.
IDK. There are lots of ribs on the back of this thing. I don't see why I couldn't make some gussets and bolt it back together. Gotta think about this.... Dang I had it going my way. LOL.
Sorry that it broke for you but assuming the dish was free then at this point all you have in it is your time. It probably won't be easy but if you are the 'technical type' and just the edges of the panels are damaged it may be worth trying to make some brackets to bolt it back together. The wife says I can be like a dog with a bone so I know if it was me I would not give up without at least giving it a try. Good luck if you proceed!
