1000.4 Aiming and Elevation setting | SatelliteGuys.US
triple835
13
UP of Michigan
Where do you align the bolt to equal 36. According to Dish Networks manual for my dish and zip code the settings are EL=36 , AZ = 170, SK = 79. AZ and Sk are easy enough, but where do you align the bolt / nut to equal 36. Top of nut, bottom, or middle? I've included a pic of my current setting. EL36.jpg
triple835 said:
Where do you align the bolt to equal 36. According to Dish Networks manual for my dish and zip code the settings are EL=36 , AZ = 170, SK = 79. AZ and Sk are easy enough, but where do you align the bolt / nut to equal 36. Top of nut, bottom, or middle? I've included a pic of my current setting. <img src="http://www.satelliteguys.us/attachment.php?attachmentid=77863"/>
Top of the metal backing.
Newbie Needs Help with DP Twin to DVR512 and D301
722k
