101 not showing up in favorites EPG | SatelliteGuys.US
When you go into the guide look in the upper left corner, there should be something that says "list:"
If you press the guide button again it should change to either:
all chan (All channels included ones you are not subscribed to)
all sub (Only shows channels you are subscribed to)
all hd (Shows only HD channels you are subscribed to)
Keep pressing the guide button to cycle through.
Note:
If you have a 722, 722k, or 622 just use the arrow buttons on your remote and press select instead of continually pressing the guide button.
A quick cabling question
622 Diagnostics
