Is there an easy way to tell if the ones on VOD are 1080P? I went through the list last night and didn't see any indication so I was wondering if you need to press info to find out. Can you tell me the name of one program with 1080P so I can download it and find out what all the hype is about?Have you watched the ones on DirecTV VOD?
Just downloaded Crank in 1080p, picture quality is fantastic but the picture jerks constantly with movement and pans of scenes. Anyone know why or have this problem with 1080p? Any thoughts?
Thanks.
Im downloading crank now and its not in 1080P according to the listing.
EDIt: it shows up as 1080P, but as Panard says but is very jerky. D* you need to add the 1080P logo's to all movies that are 1080P
Mine took just fine. But when i watch a program it has a hint of snow to it or grain not bad but 1080i looks better
YEAH! If you dont, we wont know if we are getting better PQ or not!!!EDIt: it shows up as 1080P, but as Panard says but is very jerky. D* you need to add the 1080P logo's to all movies that are 1080P
Limited time offer
