110&119 | SatelliteGuys.US
110&119
jbot
18
tampa
Hey all
My setup includes a slimline 3lnb, I noticed that I am not picking up 2 local stations. I was thinking about switching over to a 5 lnb dish, was wondering if there still was programming on 110&119 , I'm assuming that's where my other 2 locals are at
110 nothing
119 has Spanish stations, Hope, JCTV and some smaller market locals in SD
your loc says Tampa. The SD channels are on 101, HD on 103
callsign/channel/TP/satellite
WEDU 3 20 D10 or D12 @103W
WEDU 3 20 D4S or D9S @101W
WFLA 8 16 D10 or D12 @103W
WFLA 8 20 D4S or D9S @101W
WTSP 10 16 D10 or D12 @103W
WTSP 10 20 D4S or D9S @101W
WTVT 13 16 D10 or D12 @103W
WTVT 13 20 D4S or D9S @101W
WUSF 16 20 D4S or D9S @101W
WAU 21 20 D4S or D9S @101W
WFTS 28 16 D10 or D12 @103W
WFTS 28 20 D4S or D9S @101W
WMOR 32 20 D10 or D12 @103W
WMOR 32 20 D4S or D9S @101W
WTTA 38 20 D10 or D12 @103W
WTTA 38 20 D4S or D9S @101W
WWSB 40 20 D10 or D12 @103W
WTOG 44 20 D10 or D12 @103W
WTOG 44 20 D4S or D9S @101W
WFTT 50 20 D4S or D9S @101W
WVEA 62 20 D4S or D9S @101W
WXPX 66 20 D4S or D9S @101W
Never mind Ice got the info..
However; are you referring to any these in HD?
PBS WUSF
AZA WAU
ABC WWSB
TFT WFTT
UNI WVEA
ION WXPX
ok thats makes a difference ;)
Your in the Buffalo area which yes the CW & My are on 119 along with formerly WNGS (67)..new callsign escapes me
Ahhh ok that explains it, I guess for a few channels, getting a 5 lnb isn't that worth it
Just a side note wwsb is a pointless rebroadcast of abc programing and not worth even the bandwith on 103. It just covers sarasota weather which the tampa stations do just fine. Considering I live in sarasota.
Anyone know if I do add 5lnb from a 3lnb if I will have to re-aim my dish or if I add the 5lnb 110 and 119 should come in if I leave the dish settings?
You theoretically won't need to adjust it, but it may need a little tweek. Probably not though if the mast was installed properly in the first place.
what raoul said ;)
I know for fun I unhooked my 3LNB and hooked up a 5LNB and it worked fine....but that LNB was not SWM so I went back to the 3LNB ;)
Current sub adding new dish - please check my purchases
Whole home dvr problems
