Ok, I am a Dish tech with 10 yrs in this business. On a service call I ran into a real head scratcher.
Config..
D-500 plus 110/119/118.7
DP34
DP301
Apartment with flat cable passed under door from balcony.
Customer losing ZEE TV. no other problems
Chk switch result: all TPs received on all sats. Verified tp's on all sats. Signals are great on al tp's except 118 tp 20. examples 119 tp 20/ 120...110 tp 11/ 95
ONly problem is say 118 tp 20 fades.. Runs about 70 then fades to 30-40 then goes out. Changed switch same result. removed flat cable, same result. swapped receiver same result. Unfortunately we are out of d-500 plus kits, so I could no swap the 118/119 combo lnb..
Anyone? Anyone?
Config..
DP34
DP301
Anyone? Anyone?
