does anyone here have info on the size of dish i would need to get the 129 west sat in northern saskatchewan,also would there still be an open transponder on this sat that i can lock onto using a 501 receiver.thanks in advance for any help
The 129 is for hd in mpeg 4 so the 501 will not see the sat at all.
Direct receivers will not work with Dish lnb's unless you have very old legacy types.
the 501 will see transponder 21 on the 129 sat, it is the only one and is usually the strongest.
for sure easier, as the vip receivers suck to a dial in a dish.
just make sure your 501 has current firmware that has 129 in the check switch menu.
GL
thanks for the reply MikeD.i have one more question can i use my hd dtv receiver to find this sat,i would like to have my setup ready to go for when my hd dish receiver gets here in a couple weeks
Limited time offer
