Thanks guys...will take the above suggestions and report back what the outcome is.
Good note! will do that in the next few days to be sure.Have you stringed it yet, to make sure it's proper? IF not, you need to do so and get it right before locking it all down tight.
alright folks...I have the dish finally assembled and the new LNBF mounted..question is when entering my Lat. (32.464) and Long.(-80.9878) into my receiver what is the trick to entering the negative Longitude? I am using a Amiko Mini HD SE receiver. Thanks for any imput on this.
I would go with 87W, that is the closest one to you that has 24hr active transponders. I use to use 83W but 87W now. I am not too far from your QTH.also not 100% sure which satellite would be best to aim towards for my most southern bird
QTH?? not too sure what that means lolI would go with 87W, that is the closest one to you that has 24hr active transponders. I use to use 83W but 87W now. I am not too far from your QTH.
also with the data that dishpointer.com gives me about 87w it tells me my dish elevation needs to be 51.7 degrees, is this true? and setting he dish to this should get me on that bird and close to being on the rest of the arc correct? thx.I would go with 87W, that is the closest one to you that has 24hr active transponders. I use to use 83W but 87W now. I am not too far from your QTH.
OH sorry! It is a Q code or short hand in Amateur radio meaning: location.QTH?? not too sure what that means lol
I don't have the analog receiver hooked up yet...still need to get some actuator wire for it....the upright you are referring to..that is the part I have my angle count set on in the above picture?Do you have the old analog receiver moving the dish? If soo run it until until the polar mount is pointed due south. Look at the upright on the mount and make sure it is parallel with the pole. Move the dish about forty counts to the east and manually adjust for a strong signal on 87 west That will get you in the field.
ok...I will reset my elevation back to where I had it before...not too sure on how to set the declination part yet...but will see if I can figure it out lol Thx for the input!Your elevation will be the same as your latitude.Decinatoin might have to modified a bit from were the dish came from, but only a half a degree maybe.
Limited time offer
