Been a while since I checked on beams shut down, still not half the country but 6 is more than the 2 I had heard last. Your point
Dway doesn't inspect jobs, half the jobs I have done service calls on for other installers were not grounded, dishes were not solidly mounted, sloppy cable runs, etc. WB inspects jobs and they will call you back to fix them and drop you if you don't (We've had it happen to at least 2 companies/installers in this area alone). My comment still stands. As to the crosspol, if the pole is level and you set the skew on the dish to the area it needs to be in and peak it out with the birdog or any other decent meter, you will pass as is 90% of the time (and by pass I mean solid pass, nothing low). The other 10% of the time it should take less than 10 min. using the OPI. Even on this one.
As I said, WO time doesn't matter. Customer could care less.
1. Already covered in last post
2. Matters why??? We were talking about end user performance.
3. See 2
4. Last Post
5. Last Post
6. Last I checked, WB 5, Hughes 3?, WB has them in Riverside CA, Cheyenne, WY, Laredo, TX, Syracuse, NY, and Winnipeg, Canada
7. Matters why??? EU performance again
8. Maybe but clarification, WB covers the whole US although there are some areas installers don't cover (Distance/Certification/Lack of installers in the area)
9. Agree with you here
10. I'll argue this one by stating $300 vs $600, if you can't afford the $300 up front then how will you afford $99 a month over 12 (15?) months
11. Is that why it is sooo slow?
12. WB uses Docsis (? Spelling, fairly common standard I would think (cable)) Who is using the more compatable protocal?
13. That may be the official stance but I can tell you that we are doing service calls for people 8 - 12 months later that WB is still covering. Still, Dway wins this one.
14. Wrong comparison, correct comparison would be out of warranty to out of warranty, WB = Standard Service Call ($59 - $99 depending on distance), Hnet = $59 - $99 depending on distance.
15. Yes, but if you need to download a 600 meg file, Hnet = Dial up for a long time, WB = normal speeds all the way through (assuming you are under your monthly limit, which you should be)
16. The 30 days applies period as far as I know, It is in the agreement, there shouldn't be any dealers that won't honor it, if there are then you should be talking to WB. As for the charge to come take it down, Gas and time to run out the 50 - 100 miles, yes, someone better be paying for it.
17. I would agree with this one but for normal usage 25mb is plenty (my verizon account is 10mb and I havn't had a problem yet), If it is really an issue i'll send you a gmail invite
18. Wrong #s, WBs pro pak is 17Gb a month, Select is 12Gb, Value is 7.5Gb, That being said see point 15 for the main point, Hughes is 8 hours or 4 hours, in point 15 you state 8, here you state 4???. Minor detail so don't worry about it too much, bottom line is that if you spread your useage out, neither fap should matter, Hughes has more theoretical usage, but if you need that 600mb file now, WB wins
19. Covered in the last post, WB is concentrated on home usage, In general, downtime is less than 45min (15 in reality), if it is that mission critical, spend more and go with a small office or enterprise system.
20. As of right now that is correct, WB is planning on it in the future (WB1?)
21. From what I hear, neither is great.
22. Reality check, until WB came out they had canned it and were going all TV, Now they need it to compete, amazing
All that really did was point out minor details, Again, back to my original point, Overall, I can live with WB, Not Hnet, We make more money selling Hnet, but we sell a ton more WB. We have 150+ WB customers, as of last check 4 canceled after they were installed (1 was that the customers wife didn't like the dish no matter where it was and pulled it down a day later, another canceled 2 days after it was put in because Vonage wasn't working, reactivated 2 weeks later and finally canceled 4 months down the road due to money problems, another because he couldn't deal with the lag of satellite (was expecting cable type speeds), and the last because they only ordered it for a 7 day festival). Pretty good stats if you ask me.
WTT
P.S. I have only had one transponder change take less than 1 hour total (from the time I called on the phone to the time the system runs through the final registration) and that was done in 15min total, Every other time it has been at least 15 - 30 mins on the phone, 30 min to 1 hour for the noc to get it set and another 10 to run through the registration again. The last 2 times I had to do it (about 1 month ago and about a week before that) It took 2 hours (given, they changed satellites the day before) and 1 hour 15 mins. If it generally takes less for you, awesome, maybe it is just my luck
