It's not. You've got the connector problem that they discussed in the Tech Forum Monday night. I've got the problem that's fixed by a reboot (temporarily).billinmidmich said:I too have the HDMI problem with my 211 and got the software response from Dish. I was also told that they would not replace 211 as long as it was a software problem and they was working on it. My question to you is....if I could wiggle the HDMI cable(don't work at all now) and it would start working right, then how can that be a software problem?
Then how do I convice them of that. I have emailed and gave details of experiance of problem and my temporary fix and all they can say is that it is a software problem and they are working on it. I even went as far as saying that I sould get my HD costs discounted and the reply was that they would give me a $25.00 credit for my inconveniance while they work on the problem. I have been emailing with Eric.VanLaethem@echostar.com He was who I reached with that CEO email link.mdonnelly said:It's not. You've got the connector problem that they discussed in the Tech Forum Monday night. I've got the problem that's fixed by a reboot (temporarily).
retorq said:My 211 issues went away when I repeaked my dish. It helped a few others too I believe.
Please let me know what happens. I called again today and was still being told they would not send me one. Makes me mad becuase picture quality is suffering especially with the sd stuff. i told them I may have to go back to Directv and it did not seem to matter.robotech4ncc said:I too have the HDMI blackout bug that I was told is to be fixed by a software upgrade, soon? How soon? I don't believe it is a software issue but a hardware one. I plan to ask for replacemnt ViP211 this Monday. I will ask for another and another until Dish gets it right. It is easy for them to have all there defective receivers to go to what works as long as they can get away with it because its cheaper to do that then handle all the returns. Remember, the squeeky wheel gets the grease.
bumpeez said:What Does repeaked mean...
Limited time offer
