211 with EHD. Watching and recording | Page 2 | SatelliteGuys.US
Can you use multiple drives with the 211?
Do you think you'll ever be able to use 622 EHD's with the 211 or vice-versa?
QUOTE]
I have a 622 and 211, both with EHD. As for interchanging drives, unfortunately, no. They have different file formats. I have been using a WD 1T on both receivers, and the performance has been flawless for 18 and 6 months respectively.
As I have posted in the past, the 211 with EHD is almost as good as a 622/722, but you will not be able to make custom folders to place your recordings in.
I was dissapointed in the 622 with EHD, you can move, not copy programs, and once you've moved recordings to the EHD there is no way (that I can figure out) to put them into folders, you just end up with a long list of recordings with no organization.
If you have "Group" selected for your 622, your programs will be grouped in folders on your EHD as well.
Questions before I give an adverse report on technicnan
signal strength help.
