22 and subs OTA am21 in Raleigh | SatelliteGuys.US
kolodzieski
9
Apex, NC
I have a hr44/am21 -- was on a few years back getting setup info. Had a dickens of a time with the WUNC PBS channels hanging the am21 scan. Seems that has been resolved, as a recent scan (to get cozi tv on 5.2) worked just fine.
However I see from seaching around that 22.4 in raleigh is broadcasting Antenna TV, but my scan did not pick up the 22.x sub-channels. I did not use a secondary zip, just Raleigh. Should I try a secondary zip? And what should it be to get the 22.x sub-channels? They are on RF27, i.e.
WLFL RALEIGH, NC
22-1 27.3 WLFL-HD CW "CW 22"
22-2 27.4 Stadium Stadium
22-3 27.5 TBD TBD
22-4 27.6 Antenna Antenna TV
Many thanks,
Scott.
The AM21 doesn't do true scans. Only those sub-channels that are in DirecTV's database will show up.
Using a secondary zip helps but the data wouldn't necessarily be correct.
WLFL RALEIGH, NC
22-3 27.5 TBD TBD
Many thanks,
Scott.
By running Seattle WA (98101) it will give you 22.2 and 22.3 KZJO from Seattle. With an ANTENNA TV guide on 22.3. Then run MPLS/STP (55401) to get 22.4 into you DVR. You have to run 2 secondary zips to get an Antenna TV guide on 22.3 and to get 22.4 to show up on your DVR/AM21. But this is the best you can do to get Antenna TV and a guide into your DVR/AM21.
HR20-100 activation
upgraded receiver
