311 or 510? | SatelliteGuys.US
311 or 510?
Whomp
2
Jackson, MO
When ordering online through dishnetwork.com for a 4 room, HD and DVR install, there is only one option for the 1st room (811), one option for the 2nd and 3rd room (522) and a choice for the 4th room (311 or 510).
Anybody have an opinion on which of the two, 311 or 510, is the better option for room number 4?
I would go with the 510. But you will be charged $5.00 for the DVR function(unless you have the everything pac then there is no charge). If you dont need the DVR the 311 is also a good receiver.
Dhp vs buying
4 day customer, had to fight with CSRs to change Receivers
