322 install help | SatelliteGuys.US
322 install help
Stanleee
167
NY State
OK guys, I need help please. I installed a 322 with 2 cables to my DP34.I can't get it to find 119 but all the other ports find 61.5-119-110. I called a local installer and he said a hard reboot followed by a regular reboot should find it. Not my lucky day so far.Any other ideas? Like I said my 211 and 510 are all fine. Any ideas
What software is in the receiver? could be a bad or really old. should be L422 or L0XX for factory. if it's any other software power both tuners off and see if if will download. Any more questions PM me.
Change the order of your sat feeds into the dp34. If it changes then you have a bad dp34. If not then I would say your 119 lnb went bad or is out of alignment. Are you getting signal on 119?
Thanks to all. I guess I will leave it to my Sunday installer. I ordered a new 722 and they are taking the 510 and 211. I may then ask him to get the 322 working.
Satellite Tv Pirate Held In Contempt
New satellite purchase - help needed
